Hi all, need some help. We moved and lost the power cord. Cant do 1k for the Powerline right now. Any idea where I can get a replacement in the US?
I see in the UK, it’s Well Shin but most likely different here.
Thanks in advance.
Thanks in advance.
I have purchased from AVoptions for my AC Cords for my SN2, NDX 2 & XPS DR.
They also service NAIM gear.
Information found here Prices range from $40 to $219
The product that I purchased was TibiaPlus12 Deep-Cryo AC Cable (6 ft.) and you will find reviews on their website.
Thank you seakayaker! Buying now.
wait.,
lookup iceageaudio go for the copper- copper 10 awg
it wonderful
doesn’t cost much too ( relatively )
i use it with SN2 here in India
( I made sure the wiring was proper Line to Line - N to N and earth to earth )
The standard naim power cables are the ones that should be used.
Nowadays it’s the powerline lite
It isn’t too expensive
You’re going to get your post edited for linking to a commercial site.
But yes, AVOptions can hook you up.
AVOPTIONS are Naim approved servicers, so I’ll allow the info link here.
