Usb A storage size Mu so 2
Hey Everyone,
In the specs of the Mu So 2 is written:
  • Storage : USB sticks – max. 128 GB.
My question is about this max.
Can anyone tell me:
If this is true?
What happens if I plug a 256 Gb stick?
Anyone has experience with even bigger sizes?
hope to hear from you
Hi, there is no absolute limit on the size of USB drive the Muso can handle, or any other device in my experience.
You may find that a large library of music is harder for the Muso to process and index, and that navigating it through a primitive folder view in the USB input, is not ideal, in which case a separate UPnP server running on a NAS or other computer would be a better solution.
Hey Chris, thanks for your message. For clarity to say I’m not speaking about a connected drive through the usb b port on the bottom but the usb A connection on the side. Does your input still matches than?
Thanks!
As far as I’m aware there is only one USB port, on the side of the unit.
