My perception of USB cables has changed after listening to the Wireworld Platinum Starlight 8. You should try it if you have the opportunity.
Correction. The connection of the WW Electra 7 is loose with an angle but the Silver Elektra 7 is rather tight with minimal angle, almost 90 degrees into the IEC of the component.
