MikeD
1
I’ve just ripped two CD’s on to a USB stick.
Both will play from and with the stick still in, the laptop.
When I transfer the stick to my ND5XS2, one will play, the other will not.
If I try to play the “faulty” CD through my ND5XS2 from the laptop via Wifi, the laptop displays “faulty device”.
Any ideas?
Bart
2
How do you play a cd “through” the Naim player “from the laptop?”
It sounds like the usual problem - faulty usb stick - is not your issue here. USB sticks vary widely and sometimes some just don’t work right.
Do the filenames on the faulty album have a “&” character in its filename
MikeD
4
Yes! Did an edit and solved the issue!
You are the very stones of the dog, sir.
Great news. There are plans to fix that in a later version
system
Closed
6
