I have a USB drive attached to my ND5 XS2. I have two questions:
If I select ‘USB’, a list of folders is displayed and at the bottom, the playlists (M3U). But the list of folders is very long, so I need to scroll a lot to get to the playlists. Is there a way to change ordering?
If I select ‘Server’, I can see the artists and albums on the USB drive. But the playlists are not displayed. I do n’t understand why not. Is there a way to make that work?
Under Sever option, the playlists do not get imported from your USB. Instead playlists you create on your Naim device are the only option in this mode. Not ideal, but thats how it is. If you move to something like Tidal, then playlists do get imported from your Tidal account
Via USB, I think you need to explain more what you mean by this - are all your playlists in a folder called ZPlaylists? Could you not simply rename playlist the folder to AAPlaylists - or am I misunderstanding your issue?
