The USB port on the front facia of my NDS, isn’t used as all music is streamed to it, from either locally stored files or Tidal - I have actually disable it as an input in setting.
However I never liked the open port on the front, it can be seen from across the room, and the silver insert for the USB connection within the opening.
At first, I obtained a rubber blanking cap - but that was just putting a ‘bunge’ in it.
Today a set of 4 USB caps arrived, and the solution is much nicer - IMO
Couldn’t find plain black ones, as would be my preference also.
Was purely undertaken as I didn’t like the open port on the front of the facia, particuarly as I have never used it on my NDS. Tried it on the ND5XS (prior to NDS/555DR upgrade) with an iPhone/iPod, but all music originates from local storage or is internet streamed.
AQ also have plugs for unused RCA sockets, also supposed to “prevent RFI and EMI noise from entering”. This seems total BS to me, RFI and EMI is not like dust, and an unused input has its relays off.
Yes,I do, the UltraRendu/UltraCap LPS 1 is used for the SonoreUPnP Bridge to provide Roon integration to the NDS. I started with a SonicOrbiterSE unit, but had problems, so ended up with the UltraRendu. Plus if I ever need a USB digital output to a different DAC/Streamer arrangement.
I have tried a USB->S/PDIF convertor, but it just highlighted the limitations of a S/PDIF connection & protocol.
But not planning any change, as the Roonified NDS/555DR fed by the EtherREGEN is just excellent
The dual faceplate just tidied up the two units up, given there is a dual 5V/12V LPS, a further 12V LPS, the LPS energising PSU and the charging supply for my Bakoon phono stage in that space under & ‘at the back’ of the Aavik table.
I know, and that’s totally fine and a good use for these caps. Though do paint over the AQ logo, it hurts
If AQ marketed it purely as dust covers, no issue. I was just commenting on the claimed RFI/EMI protection (which I therefore quoted), stuff like this IMHO puts question marks on everything the company sells.
Yes, I have an Orbe turntable, on an Aavik 5-tier table, on Nordost Titanium Pulsar points.
I also have an Aavik Titanium table next to it, but unfortunately only a 3-tier table.
