So are we all buying them for our laptops and PCs?
If you do feel the urge and don’t want expensive “hi-fi” ones watch out for those cheap ones for sale on eBay and Amazon as they come in two types:
1 to go over a USB plug you aren’t using, which won’t fit into a socket and 1 which is to block off a socket.
You need the latter but the text doesn’t always state what you’ll be getting. @litemotiv shows the correct type.
