Given the level of your system, there are probably 2 “best” options, add another level to your rack(s) and use a Naim streamer, or the option you ruled out……
Well I’m obviously prepared to throw the cost of an Atom HE at this and maybe a bit more, rightly or wrongly. Sources would be Tidal and 26,817 tracks on a QNAP, the majority FLAC.
Both aren’t wrong, but neither are an option for me for different reasons.
The earlier Aurelic Aries (the streamer only version without pre-amp) are well regarded. Not sure of the size though.
I am using my new Atom HE as streamer for a NAC52/Supercap/NAP250 system:
I was looking for a compact streamer that would also add Headphone out to the system.
The streamer is set to around 65-80 but most of the volume is controlled by the NAC52. This gives more room on the NAC52 volume control with my fairly efficient Devore speakers. I am not worried about multiple preamps as the Atom is digital domain only anyway. [note correction from below - the volume is indeed analog!]
The system is used otherwise primarily with a Linn Klimax/Aro/Keel vinyl system.
I am not sure how much I am missing compared to say an NDX2 - might have to find out someday….
What about the Uniti Core?
It sounds like you may not need all the functionality of the Atom HE? Or do you also need a DAC in your setup?
Ah yes, no dac. I thought the contrary….
Bel Canto E one stream. Just checked: it has an onboard dac. Shoebox size.
Think that, for the Price , its unrivaled
How about a Leema Acoustics Elements Streamer…
Thanks, ticks the boxes except perhaps performance. I take positive reviews from What Hi-Fi with a large pinch of salt, negative reviews less so, but 3* is very underwhelming.
I am out of propositions, because the shoebox size is not so common.
I found however a last one: Innuos Zen mini with its additional psu. You can find a detailed review in Darko audio site.
I very much appreciate your efforts. I don’t have the height on my rack for two boxes or the width for them to sit side by side. My dealer tried the Atom HE as a standalone streamer and thought it sounded better than an ND5 XS 2 despite the redundant preamp functions so that’s probably what I’ll end up going for. I’ll do a home audition first to be sure it sounds good. I’ve already got a non-HE Atom in another room (but not using preamp out) so I know I’ll be delighted with aesthetics and functionality. Still curious regarding best way of setting up. My dealer thinks set the volume at full on the Atom as that’s what a fixed output would be and then use the 552 volume to adjust.
Atom HE, despite some redundancies, is perhaps the best choice finally. And it looks much better vs all the choices above.
The only problem is that the A HE digitises the volume control. Hope it will sound still very good in your set up.
What do you mean? I know the volume adjusts from 0-100 but why would that be a problem compared to an ‘analogue’ setting?
@ChrisSU :
“ The Atom HE is designed as a standalone all-in-one device. I can’t see much point in trying to link it to a Naim preamp, especially as it digitises its analogue input.”
Chrissu will explain better than me , specially as I am not a tekie, neither English is my native language.
It digitizes analog inputs, but that’s not much of a problem when used for digital streaming
The volume control, however, is analog although it’s controlled digitally:
So you think that connecting the Atom HE to a preamp is not a compromise?
I don’t know personally.
Another one to consider would be Goldnote DS-10. I tried it in my system once but compared to my NDS/555PS DR it fell short. I can’t really comment on sq other than the above.
Cyrus comes to mind for shoebox sized kit.
