I was hoping someone knows if it possible to connect two sources to the AV bypass input on the Naim Nait XS3? The manual says not to use both RCA and din inputs - does anyone know why not if the inputs are never used at the same time? I want to use the Nait XS3 for my both my AV processor and for my digital preamp that handles my subwoofer crossover and room correction software. The AV bypass input is ideal for both and I’d rather not have to swap cables every time I need one or the other.
Thanks for this. I can see this would work. Not sure about having another box in the signal path. Might just have to switch cables each time, pretty quick if I use DIN. Shame there is no way to use both DIN and RCA connectors on one input.
