Using nd555 remote with automation triggers change of input on 332
A while back we had a thread on automation using the nd555 remote to control volume, mute and the rest of the streamer functions available. This works fine when you learn to live with having to power down the 300 setup yourself.
But after I started using one remote I have found that some presses on volume up or down instead of changing the volume changes the selected input. So to get music back I have to find the 332 remote and avoid using two remotes was the main idea for setting up automation in the first place.
Removing one of the batteries in the 332 remote seems to have solved the problem, but not in the way I hoped to.
Claus
