I’m getting very little and sometime no sound from my right speaker when streaming, but seems ok when playing vinyl - any ideas folks?
System: LP12/Lingo/Ittok LVIII/Adikt, ND5 XS2, NAC102, NAP180, Olive Hi Cap on Ash Rack. NACA5, ATC SCM40 speakers
Cheers, Geoff
Assuming that the vinyl ‘is’ not a problem you need to troubleshoot the input to the pre amp from the streamer (maybe swap to another input ?) to see if it is the pre amp input that is the problem and also if that has no effect it sounds like either a streamer issue or an interconnect issue ?
Hope this may help you to isolate / rule out different possible causes ?
swap the inputs over and see if the fault moves.
