Vintage NAP 250
Hello,
I have a Vintage NAP250 from 1985 I am thinking about sending back to Naim to get refurbished. I have it since new but many years ago sold all of the other equipment NAC 42.5 / Snaps. Is there still equipment available to buy to set up and use with the Amp. used to love the sound!
Thanks for any advice.
Steve
Your dealer should be able to advise on 2nd hand equipment.
You can get the amp serviced by Naim, or by Class A, their authorised service agent in Sheffield, assuming you are in the UK. The latter can be easier, and is cheaper and still uses parts supplied by Naim.
The amp ideally needs a Naim preamp. Any of the later models will be fine, but there are plenty of used preamps (and power supplies) around if you want something that’s a visual match.
Depends on budget and if your willing to purchase new or s/h.
Buying new, the Atom HE or NC 222 could work as one box solution together with your poweramp, extra cables might be required.
Then there’s further up in NC range with separate power supplies.
Second hand options is many.
A 250 is a lovely thing, whatever the vintage; worth treasuring and savouring. Bring it back on song!
