I have:
An Audioquest vinyl brush
Zomba stylus cleaner ( gel pad)
Lyra stylus fluid cleaner ( used from time to time)
Art du Son lp record fluid
Digital stylus balance
And soon will buy the HumminGuru ultrasonic vinyl cleaner
My accessories:
Ursa Major carbon fibre brush - excellent
AT637 stylus cleaner - I use sparingly as I am wary of damaging my aluminium stylus, which are prone to bending.
HumminGuru ultrasonic record cleaner - appears to improve SQ for records that are already clean
Analogue Studio anti static record sleeves
Analogue Studio Resealable outer record sleeves
The above gives me silent playback for around 90% of my record collection, a mixture of new and second hand.
HumminGuru record cleaning machine
Nagaoka antistatic inner sleeves (not the cheapest but very worth it)
Carbon brush (the silver one that is available from a hundred brands, mine is from Pro-ject)
DS Audio ST-50 stylus cleaner (gel pad)
Digital gauge (I have a Rega Atlas but frankly all you need is the grey one for 6 euros that is available on Amazon with a hundred different brandings)
Wow!! Thanks to all who replied! This is exactly the sort of information I wanted! Some solid recommendations that I can look into and some options within each category!
Perfect!
Try not to blow the budgetā¦ Baby stepsā¦ Start small ā¦ And cheapā¦
Pro-Ject RCM
DS-Audio ST-50 Stylus Cleaner
Record cleaning brush - Levin Design Germany
I find a quick wipe of the fibres on my jeans works a treat to lose the gunk on the fibres. Itās a tip I picked up from Peter @Cymbiosis . Seems crude, but works perfectly IME.
Checkout Blake Sleeves on YouTube, they are the best thing Iāve bought for my collection.
They have an adhesive flap on the back so you never need to remove / damage the album cover. I take all my inner sleeves and put them at the back of the Blake Sleeves with the slot facing upwards so all I ever take out is the physical records.
They are fantastic quality and really make the artwork pop.
They do sleeves for gatefolds and regular 12ā. You need to order from Netherlands but they come super quick.
Ditto - I use the AT once or twice a week and green paper before each side.
I donāt clean records. I just buy them in very good condition and look after them. Mind you, my systems are not high resolution by modern standards and I donāt have an expensive cartridge to protect. I couldnāt be bothered with a record cleaning machine either.
Donāt panic!
You can do as much or as little of all this as you like.
I have over 700 LPs, mostly bought in the 1980s and mostly second-hand. I am also more annoyed than many listeners by clicks. So I got a record cleaner and most records have been cleaned once in the last 6-7 years.
If the records were all new or if I had a few, I would not have bothered.
I use a gadget like those shown to clean the stylus every 100-200 plays or when I notice it sounds odd or apparently has a blue-bottle attached.
I use one of those dust removing brushes on an LP if I notice itās dusty. I prefer doing that well before or just after playing, to avoid static electricity issues.
None here matches my choices exactly - we all make our own choices about what is too much bother, and I am sure you will end up doing the same.
None of this matters as much as finding music I like and listening to it as often as I can. After all, given a choice between a tatty copy of Kind of Blue or a pristine pressing of Celine Dionās Greatest Hitsā¦
Thank goodness. I was going to mention my cleaning the bristles this way, but balked at what I thought would be inevitable reactions!
Phew.
I would definitely avoid fingers as the greases will stick to and build up over time on the fibres.
I usually use a little brush, the kind that used to be supplied with the big LP brushes back in the day that look like a sort of mini toothbrush with a single row of fairly stiff bristles.
Hmmm, thatās interesting. Iāve been using my fingers after reading the below in this (The Analog Relax Record Brushļ»æ - The Vinyl Press) article:
Before I was using my jeans as suggested above, but at some point figure that who knows whatās on there. And then I read this and figured that at least I wash my hands regularly.
Maybe itās specific to this brush
The brush mentioned I still mean to try some day.
Ok, so I have another fix for this. I have a Decca Brush - which is probably the original design of these. I think I need a picture hereā¦
The clean the dust off the brush, you put it back on its stand and wizz it back & forth a couple of timesā¦ But - after a while, the bristles tend to get splayed out, laterally. To fix this, you take the brush off its stand and wipe the bristles cross wise. This will put them back in line.
I was shown this last trick by Derek Whittington formerly of Sound Advice, Loughborough.
Does it have bristles both sides?
IMV itās a better product than the Hunt EDA and looks far more āidiot proofā (where I fit in) in practical terms.
Errā¦ yes, of courseā¦ Donāt they allā¦
Looking at modern versions, the Project one seems most similar to the Deccaā¦?
But - I see there is a modern version called the Deram Brush which is a single row. Hmmmā¦ NOT the same.
Yes I think so - but as the aim is to use the fibres vertically and then the velvet to collect/lift the dust, I wondered if someone had made a one-sided version.
IMV, this would make the dust easier to lift away?? Just a thought.
Thereās a āusedā Hunt EDA on a well-known auction site at the moment. Letās just say, it looks very āusedā.
Ohā¦ Yukā¦ horribleā¦
I always found the the Decca Brush (original) just worked. There is another trick to minimising static. You try not to clean for too long then sweep the brush over the centre spindle.
Hereās a picture showing the 2 rows of CFās:
Conversely, I have an old and also a much more recent Decca 2+2 brush, and I didnāt really like either of them, so I guess much will depend on personal preference.
Mine is from the 70āsā¦ so its younger than I amā¦
YYMVā¦ its the Interwebzzzā¦
