Vinyl Box Sets With Foam Packing - a warning
If you have the above/similar stuff which is aged, I’d recommend opening-up and checking the interior packaging. Having checked a DG classical 'set (bought in '90s) and a MoFi 'set over the weekend (latter c.2013), in both cases the foam had disintegrated, thankfully not overly sticky though - although the DG one was going that way.
Foam inside multi CD box sets can have a similar impact and is best removed.
Not just CDs, the foam in my LZ box set went sticky and had to be removed - thankfully no damage to the box or vinyl.
