Keith Monks used to have a list of outfits who would clean lps for you. I used to use a shop in St Albans but it closed down a few years ago.
I’ve never used (or heard of) Audiozomba. Maybe they do a good job or maybe not. I used to get records cleaned for £1 each at a local dealer on his Project machine. Eventually, the guy suggested I buy my own machine as I was taking so many records to the shop. I got a good deal on an end of line Project VCS2 and consider it to be an upgrade to my system. I wish I’d bought one sooner.
As others have said, why spend a few hundred on having your records cleaned elsewhere when for similar money you could do them yourself (even just a few per day) and have your own machine.
Your money, your choice though obviously .
The list of Keith Monks cleaning centres includes Russ Andrews and Grahams HiFi, for example. No idea what they charge.
I’d gladly clean people’s lp’s for $2.50 each. Help pay off the capital sitting in my rcm.
I’ve literally just yesterday sent off an l.p. of mine go analogue seduction for a clean. Will let you know.
Cost about six UK pounds Inc post ECT
I use to clean vinyl with gin and cotton wood. It did the job well-enough.
So to get a job lot cleaned… Say 100 records… ain’t going to be cheap. Much more than the £300 or so it would cost to buy yourself a machine I’d imagine…
That’s what we’ve all been saying
Yes, but I don’t plan to get all mine done. I plan to see what the result is and consider buying a unit.
Where are you based in the country? I’m happy to help get the old man’s records clean for you.
100 records at 3.6 minutes per record is 6 hours. That seems like a big chore. I appreciate that some would enjoy the process, but not me.
£300 to get them all thoroughly done and then just give them an occasional once over with the Disco Antistat that I already have somewhere is an attractive option.
Thanks Horses, that’s a generous offer. Not one I feel able to accept though.
3.6 minutes per record is incredibly optimistic
But made the maths easy
Even more reason to send them off for someone else to do.
Everyone who owns a decent rcm knows what the result is and can tell you. You don’t need to do the experiment yourself. This is 2020; a good wet rcm will improve your vinyl playback a lot. Now you know!
Was meant as a reply to the OP… Apols.
I have a strong opinion. But I’m going to be quiet
I’ve agreed with everyone that I will get an RCM. For ongoing maintenance and new purchases it makes sense.
I just don’t fancy wading through the backlog.
Oh go on Opus, do share!
As long as you don’t mind me having a different one.
I agree with the sentiment that life is too short to spend hours cleaning records. My approach was to invest in an Audiodesk ultrasonic job and only do a record when I want to play it. Pop a record in the machine, go and listen to some music ( it is relatively quiet). 5 minutes later you can take the record out.
