Volume Control on App
Maybe I’m missing something here. On the Naim app that I use to control volume on my 552 is there a setting to be able to see what level the volume is being played. I must be doing something wrong. On everything else I own it’s a 1 to 10 or 1 to 100 visual setting, even a colored moveable bar. Now I just “guess” what it is playing at, it must be me. I’m using an iPad or iPhone.
If you’re using the system automation, it works by sending an up or a down signal to the pot motor on the NAC552. Because it’s just an analogue pot, there’s no two way feedback, so an indicator is not possible as the app would not know where the control is set. Best to judge using your (analogue) ears.
