Last week a close friend gave me his Walnut MK1 SBLs with MK2 drivers, they need cleaning up some new grills but overall in excellent condition gaskets are intact too!
Project for the New Year as the SBLs will replace the Allaes that are currently on the end of my CB Nait 2.
They remain the best speakers I have heard. The latest Kudos etc may be better but at a price and, without a home demo, no way to be sure they would work in my room. I hope you enjoy them as much as I do!
Hi, I’ve just done a pair of cherry SBLs and found the 2 tubes in the bottom box were loose as the silicon was past it, worth checking before assembling them. I managed to remove the old silicon and replace it without stripping the cabinet from the frame.
That’s even more of a bargain than my second and current pair of SBLs, which I bought for a few hundred pounds. A pristine pair of teak mk2s, which might well be all the speaker I ever need. I hope they work for you as well as mine do for me. Edit. I’ve just looked at the original order and I think mine might be walnut and not teak. Anyway, i like them a lot.
Thanks Chris, it’s probably the light in this room or the age of the SBLs as these are MK1s with MK2 drivers the serial number 74xxx dates them 1991, not quite as old as the Nait 2 though (1988) hard to believe these are now over 30 years old!!
