Warps are a thing of the past for me. I use a 850 gr spindle clamp and a 1500 gr outer ring on my turntable. Those flatten all kinds of warps (both concave and convex sides) and couple the record to the platter (a POM without matt) to eliminate any chance of resonance.
What kind of outer ring is that? I was not aware such a thing was available to cure warped vinyl.
Mine is made by Clearaudio and is specific to my Clearautio turntable. It wonât work on other turntables, but there are 3rd party ones that might work.
But you have to excersize caution. If your turntable isnât designed for such a thing the weight of it can cause damage to your platter bearing. I doubt one would work on a Linn Sondek, for example.
Thanks! I will investigate that. I find it looks nice as well! Surprised this isnât more common as there are more than enough of different central clamps/ wheights to choose from.
I have a Dr Feickert Woodpecker. Construction and platter seems a bit like the clearaudio so it might hold up ok. But it needs to be checked as you say.
The Clearaudio has a magnetic/ceramic bearing, so the subplatter floats magnetically on the bearing. Thatâs why it can handle the additional 5.5 lbs. of weight. If the Woodpecker uses a more standard mechanical bearing (like what Rega and many others use) it may not safely support that extra weight. Clearaudio and VPI turntables are designed for use with outer rings. I would caution their use otherwise.
If you look at the top photo very quickly, you could be forgiven for thinking that itâs a black Ittok or Ekos, but then you ask yourself whatâs happened to the counterweight at the back of the arm. Then you look more closely and see that itâs offset to the right.
Thatâs the Clearaudio Universal tonearm. What you see offset to the right in the top photo is not the counterweight. Itâs the anti-skate adjustment.
Itâs a remarkable looking design, but there must, surely, be some sort of counterweight?
There is. Look at the second picture. Itâs the polished steel one hanging below the back of the arm on the adjustment screw. Itâs mostly hiden in the first picture. Itâs also replacable. The arm comes with three steel ones and two alumninum ones of different weights, to accomodate the weight range of various cartridges.
Thanks. I think that Iâd need to see it âin the fleshâ (as it were) to grasp fully how it works. Is that a Dynavector cartridge on board?
PS Yes it is, as your Profile confirms.
Yes, a DV XV-1s. I have a Lyra Altas SL coming. I have heard itâs finished and on the next shipment from Japan.
This photo might help a bit. The silver counterweight moves back and forth on the threaded shaft. The knurled black knob off the back of the tonearm is used to move the counterweight back and forth to adjust VTF. The other double knurled black knob off the side of the tonearm fulcrum is the anti-skate adjustment.
How does it compare to your NDX2?
My TT with Superline/SCDR is much better than the NDX2/XPSDR, but itâs also about twice the cost.
Thanks for the explanation. It looks very complex, compared to my ARO.
But looks donât contribute to the sound, of course, and thereâs more than one way to skin a cat.
Iâm not sure why you see it as complex. Itâs quite simple to setup actually.
- adjust the height of the arm in the armboard for VTA
- set the VTF using the knurled knob on the back of the arm
- adjust anti-skate using the knurled knob on the side of the arm
The most complex part is mounting the cartrdge and aligning it. But thatâs true for any arm that doesnât have Regaâs 3-point pre-algnment built-in.
The arm is sophisticated, but built like a tank, and the fit and finish is amazing. Itâs also over $6k, but you are gtting what you pay for.
Thanks for your very full explanation. The arm tube looks as if may be made from some form of composite material, is it glass fibre, perhaps?
Many, many years ago, I had a Japanese-built (I think) Infinity Black Widow tonearm, which had a glass fibre arm. It looked beautifully finished, but the main bearing design was not sufficiently rigid for the design to work properly. I have no idea what I did with it. I probably sold it for next to nothing for a friend.
The arm wand is made of carbon-fiber. It is in three sections to help eliminate resonance. Itâs not adjustable in any way.
There is one other adjustment that can be done. The headshell can be adjusted for azimuth, but that requires a special tool and test record, and is generally unecessary.
Thanks for that. I donât actually know whether carbon fibre and glass fibre are different materials!
Yes, they are different materials.
Thank you, you never know when these titbits of info may come in useful.
