Welcome to Naim Peter, its fun place.
Once you get the Naim app the rest is easy, Synology ‘Media Server’ is OK, but its very basic & doesn’t get the best out of NAS streaming.
Get used to the app first, with Media Server & take your time playing with the new toys.
Then think about something better; Synology Package Centre has a 3rd party server called ‘Minimserver’, this is a huge step up, I used it for a year or two, but its a bit of a faff to set up if you’re not so confident with 'poota stuff.
However better still is available - Illustrate (dBpoweramp) have introduced ‘Asset UPnP’ for Synology & this is just so easy to set up, install & go. You get it with a web search ‘asset upnp’ & try the free 30 day trail version, it has limited features, but even that is better than Media Server. The full program has so much more & then some, is a pay just once £23 for the full licence & lifetime support with updates as & when.
Yeahhhh thanks. I had that app installed already but was confused with the NAS setup.
Now that I revisited the NAIM app thanks to your sugestion I have figured it out. It was right there.
So I deleted n-serve and have it working in the Naim app indeed.
Thanks a lot!
Happily streaming my local collection of ripped CDs, Spotify, Qobuz, Radio Paradise and other radio stations to a Muso-2 …
As a server, using a Mini ITX PC running Daphile with UPnP bridge, RP, Qobuz , Spotify and Material Skin plugins (cost about $350 US, Daphile free, plugins free).
Control Application is Material Skin (free).
I’ve also used Asset UPnP on a Synology NAS and would recommend it as well. I do not use the Naim application.
