Yesterday I was baking some bread and as it was a bit cooler in the kitchen-dinning room my bread dough was slow to rise. I realised that the unitlite was always warm to the touch, so placed my dough in the kitchen aid bowl on it. It worked really well and in the future I will be using the newly discovered naim technique on cooler days when I am bread making.
Had no effect on the sound as far as I could hear. The problem was that bits would fall off and I’d have to remove them from the CD well. (using a hand-held vacuum cleaner).
Since my original post, I remember that my then cats used to like Naim kit, one would snooze on the 140, the other would snooze on the hi-cap. Fortunately, a coating of cat fur had no impact on the sound quality of Naim amplification.
What could have had a seriously detrimental effect was when they were kittens and fascinated with turntables and arms. This was discovered when one batted the Ittok Asak combination across an album, fortunately with no damage. This resulted in playing albums with Linn’s lid on and down becoming the order of the day, potentially saving severe damage to my wallet.
You might want to think about having your Unitilite display turn off after a short time, as otherwise you will probably need to get it replaced by Naim in a year or two, which they might or might not charge for doing.
Well whatever! The displays on these old Naim streamer models do regularly fail though and the only way to avoid it is to have the display switch off after a few seconds. It’s a back to Naim job if it needs a new one.
Ah yes, I well remember the horror of watching Suzy Wong stepping over the Zeta (which was up on its lifter) and discovering the bouncy platter on the Sondek…fortunately the was no LP, and it did bounce rather well
This is the same Suzy Wong who used to jump down from the curtain rail onto the top of one of the Isobariks…
There are some posters who won’t know that Suzy Wong is a sadly lamented cat, they’re now thinking you bounced on the LP12 and leapt from the curtain rail onto the speakers.
