Hopefully Naim will take a look at this thread and add some of our ideas into the app.
I’d like to see a Sharing function and lyrics, the later could easily be pulled from TIDAL as part of the subscription.
Any others ?
Probably better to be added here in the existing thread:
As for “lyrics can be easily pulled”, this depends entirely on whether Tidal provides an API function (and possibly license) for 3rd-parties to do that. They may or they may not, I don’t know, but if they don’t then it’s not easy (or rather impossible)
Better (much better) Tidal integration.
‘Statement Mode’
Ability to access masters recordings - can on iPhone through tidal direct, can’t with Naim ……where it should be ideal
