I don’t fully understand your first sentence. English is not my first language. But if I offended in any way it was not my intention and I am sorry about that.
Oh, now I understand, haha. I felt inspired by the Netflix series ”Lucifer” at the time.
Regarding the Hicap vs Hicap dr I found the latter cleaner and smoother sounding. However, the Hicap was about 7 or 8 years old and the DR was new. So that might have had an effect.
Hello, I understand the 82 with two HiCaps is the sweet spot, an SC is better but not by much, so if two x HC2 or HC2DR are out of reach it might be worth considering a pair of olive HiCaps if they are serviced.
Naim power supplies generally do bring a lot of improvement wherever they are used in the component chain.
My HiCaps are olive and chrome bumper non-DR models.
Given that the DR technology is designed to provide cleaner power I assume the DR HiCaps would undoubtedly be better than older ones, but I guess it all depends on cost/availability if you are looking at pre-owned as new the only option would be DR.
I have 2 non-DR NAP 250s which are excellent. I have heard a NAP 250DR/300DR and they are definitely better - silence is ‘blacker’ and control generally better (the 300DR is phenomenal), though perhaps the older ones sound warmer to some extent.
I suspect someone else will be able to more accurately describe differences, but I think either HiCap would be a real boost.
When my son was very young I simply Gated off the Room my Hifi was in. As he got older and could understand no, and the implications of touching Dad’s stuff I never had any problems
I have an 82 and had one olive hicap and then added another olive hicap with a 250CB. Then went 2 x 135s and changed to a Suoercap 2 non DR.
The hicap is needed to run the 250. The 2nd hicap improved things alot. The Supercap even more. Having had them all but non DR the Supercap is worth it. But 1 or 2 hicaps are both excellent.
But source first!
Have got Focal Aria 936s, large floorstanders, reasonably priced with plenty of oomph.
I see. I will probably move up the psu ladder in one way or another.
The “source first” is sorted with the Lilnn streamer/ DAC. Sounds faboulus. Speakers on the other hand… Well it is kinda sorted because i really enjoy the Focus 160’s. But I suspect I will enjoy a good floorstander even more.
Ok. Thanks Chris. So two HiCaps would be preferable given that I use the StageLine.
Which brings me to another question regarding psu’s: How is the Flatcap 2 compared to the onboard psu in the NAP 200 non DR? I suspect that the onboard psu in the 200 beats the Flatcap 2 in terms of powering up my NAC 82. But I wouldn’t know for sure. I ask because if the Flatcap is the better one it could power up both the 82 and the SL, and relieve the 200 as a psu.
My sources is Linn Majik DS and Pro-Ject 1Xpression into Stageline N, before the NAC 82. I might just try it, but something tells me that the onboard psu of the NAP 200 is better than FC2. Dunno why…
I’ve never had a Flatcap of any descriptuon but a quick search suggests a FC2 can power 2 devices - 82 and stageline may be too much for it, you’d presumably need a 2nd SNAIC, but I’d at least try it on the 82 alone - if it gives a boost it may show a little of what a HiCap would offer.
I used to own Dynaudio focus 160’s, they do not have any way to screw them to stands without DIY, which would ruin the speaker bottoms. I used the Dynaudio stand 4’s with mine at the time with bluetac, which made them really secure. Other than a kid tackling them, or a direct hit from a dog, that is all you really need, my stands were filled with dried sand. I later changed to C1’s, which do have screw inserts on the bottom, but are more top heavy.
