What is it about a Sub
Please don’t think this is a critical or confrontational question but I notice more and more the use of subs is becoming more common.
Having never had one in a Naim system I am curious to know why you have them and what started the path to placing them in your system.
Was it to make up for something missing, increase the enjoyment of your system and how it achieved a greater listening experience.
As I said I am curious as they seem to be more in vogue than a number of years ago.
Nice replies please.
For a moment I thought I had accidentally logged into a sexual fetish site….
Sister xx
Just people trying to get bigger speakers on the cheap.
:popcorn: :dashing_away:
In my case, the subs were my last ditch attempt to correct a nasty bass node at about 42 hz in my new room. No combination of acoustic panels and speaker positioning could touch it. Tried different speakers and that helped a bit but still not acceptable long term-I didn’t want to listen to my system. Main culprit is odd dimensions of listening space and construction materials of the room.
I have tamed the bass modes and flattened my room’s bass response with 4 X 12.5” passive subs paired with dedicated controller and amplifiers. I no longer “hear” the bass. Gained dimensionality, soundstage, grip/impact- the best bass I have ever experienced . The bass is the same throughout the room-not just in listening chair.A revelation, really. Subs can transform your experience. No boom-boom here, just enveloping musical experience.
Well, if I was going to participate by answering the OP’s question honestly, your trolling certainly took the wind out of those sails.
Hi.
I have Graham Audio LS5/9 speakers and Graham Audio manufacturer matching passive subs, Sub 3.
You can use the LS5/9 as is but if you consider the base a bit light in your room you can add the Sub 3 passive subs.
The subs have no controls and do not require a power supply.
They are designed to be tucked out of sight behind the stands of the LS5/9.
I have an active system but could not afford the additional 250 or pair of 135s necessary to fully run my speakers. A REL sub was a cheaper option, which I don’t regret.
I have Martin Logan ESL speakers - electrostatic speakers. Whilst I really like the mid and higher range they lacked bass drive to my ears (and visitors). Rather than changing the speakers at the time I decided to add subwoofers. These certainly have added more bass but also enriched the mid range.
Question is could I have achieved this with different speakers but without adding the subwoofers? Possibly? A pair of floor standers providing the sound I am looking for would be aesthetically better. However, in my case finding a dealer with a range of speakers to listen to and then arrange for a home trial was not possible.
Pros; A subwoofer often has more freedom to be manoeuvred around the room than your speakers which can be a huge advantage. If finely adjusted they can make speakers truly full range, something even larger speakers often can’t do without assistance of a subwoofer. Todays subwoofers, especially if chosen from a Hifi rather than Home Theatre perspective are faster, cleaner sounding and more powerful than many specimens of thirty or even twenty years ago which many still associate will long held believes that subs are slow, pondering and can’t be properly integrated with smaller main speakers. Long held believes are sometimes difficult to change! Subwoofers can work equally well (or especially so) at lower volume and you often can programme the settings according to your needs.Some/many have dual inputs so you can have them connected to your HT and Hifi. They may also come with remote which makes set up a lot easier. You may already have a smaller speaker you love but occasionally want more bass. A sub is an ideal addition. If your listening volume rarely approaches wall rattling good subwoofers don’t need to break the bank. If you have a problem room with regard to bass nodes or pressure peaks (room modes) and little room to move either your speakers or your sitting position, a subwoofer can help overcome this. Often, the addition of a subwoofer can take away the perceived sting of a smaller front speaker which comes over as treble biased, giving a more balanced and relaxed sound.
Cons; Some don’t know how to integrate a subwoofer with their speakers which creates obvious problems. It opens the possibility for endless fiddling if you are so inclined. Two subwoofers can be better but the outlay is greater and set up options will be tighter. If you have a real problem room a subwoofer may still not help to overcome this issues. Some (me) actually find really extended bass distracting rather than to add to the experience. Subwoofers rarely are the prettiest things, though things are getting smaller and better and you still have to find room for one (or two, four, six …). A tiny main speaker with a small main driver will still be dynamically stilted at higher volume. A sub will not change that. Real (!) stomach pain, anxiety inducing, deep, powerful bass still requires large cabinets and drivers, even in subwoofers but if perfectly placed, with room assistance you can get close even with smaller, lower powered examples at lower volumes. Although low bass is usually regarded as omnidirectional many find subwoofers are still preferred near the speakers if the room permits this.
I used a pair of Rel subs with my Naim/ATC system. For me personally it’s about information retrieval and I find that my system is more revealing when the subs are on. The concept of a subwoofer is not so different to Linn’s Isobarik approach or other speaker loading strategies that aim to increase the effective area of a speaker driver to improve the retrieval of bass information.
You’ll have to enlighten us as to sub fetishes…
Why? You know more than most including me with the six monsters you have …
A good sub just makes everything sound more solid and real, more in the room. A bad sub goes boom boom boom!
Because sub threads tend to attract trolls and become toxic as a result. I don’t know why but they do. It’s not just here either. It seems to happen with all forums.
I’ve spoken here about using subs in stereo systems, and why they help. I don’t need to repeat myself. It’s in the forum already.
I have one to fill in the frequency response that exists in real life music that my speakers do not produce.
The objective is to reproduce the sound made by instruments with my stereo. Sub helps with that.
My Hi-Fi is extremely modest by the standards of this Forum but I have long been curious about the use of sub-woofers and I recently bought a small REL to try out with my small stand-mount speakers.
Not because I wanted more bass but because of the claims that by relieving the main speakers of the deep bass load, it enables them up to do a better job with the mid-range, where most of the music resides.
I connected it up and started streaming from Tidal and was sitting there thinking “Well it’s certainly different but it is actually better?”
My wife who was sitting reading at the other side of the lounge and taking no particular interest in my tinkerings suddenly said “Wow, Van Morrison’s voice sounds much clearer than usual tonight.”
I’ve kept the sub. I run it with its volume control set quite low and it’s also helped to control boomy bass in our 4m by 4m lounge.
People sometimes say this, but with the vast majority of subs it’s not the case. The main speakers continue to receive a full range signal from the power amp regardless of whether or not a sub is connected, either by a high or low level connection, so they are not “relieved” of anything. That isn’t to say that a sub can’t bring perceived benefits to sound quality across the frequency range - I’ve heard that effect myself, so I’m not saying this to argue against subs in HiFi systems.
(There are some subs that have, in addition to a low pass filter, a crossover that removes low frequencies from the signal that is fed to the main speakers, or you can buy a separate crossover specifically for that purpose, but these are not common.)
I’ve gone through a cycle of trying a sub, not liking what it did, subsequently removing it before trying again. I’d bough a cheap and a bit broken REL sub from eBay years ago to go with my then NAD/B&W system where it worked reasonably well connected to said amp’s sub-out via RCA’s. I fixed the sub with a bit of superglue (on REL’s advice :joy:) so knew it was functional. Problem was it just didn’t work with my SN3/Focal Kanta system at the time so I parked it in a spare room gathering dust. Inspired by the proselytisers on this very forum I decided to try again years later when I’d upgraded to pre/power. I bought a neutrik cable to connect direct to speakers and invested a bit of time experimenting to dial things in. Within half an hour of playing around I recognised what others are talking about when they describe the more subtle factors of soundstage, enhanced mid/highs etc. fast forward an I really couldn’t imagine system without its synergistic impact.
Despite having very capable bass reproducing amps and speakers and a fairly sympathetic room it’s convinced me of its place as a small but significant part of the whole. For those in any doubt I’d always recommend a suspension of disbelieve and/or bias and just try. In my mind it’s worth it even with a sub that cost me £150 2nd hand, I’m sure a better sub would bring even more benefit but it has to be one of the best value upgrade I’ve ever made.
The argument against subs has always been they don’t integrate. With my electrostatics that was certainly true for a long time. Subwoofers were just too slow.
Not true now however. The Rel 510 integrates beautifully. The new 550 is even a bit better. If they can integrate with electrostatics then they can integrate with just about anything.
The key is less is more. Too much on the dials and they stick out like a sore thumb and slow down the midrange. Solution is turn the dials down. And if you think you don’t hear it remove the sub and you will realize what an impact they are really having.
I don’t have, nor have I ever heard a hifi system with subs, but in case of interest this is my view and understanding: Decades ago subs were primarily to provide sound effects for home cinema and similar, though people started using them to add low bass to limited speakers. I wasn’t interested, believing it was better to spend the money and get decent speakers that do good bass in the first place. Roll on a few decades and I think subs capable of playing music well have come of age, and offer a realistic option. There are pros and cons to subs vs true full range speakers, subs offering greater potential flexibility in setup and tailoring to the room, and making it easier to have taut upper bass as well as full range, however to work effectively as a whole the setup may be more complicated than many people realise (positioning, cut-in/crossover frequency and slope, phase and relative sound level, though tools like REW with a measuring microphone would greatly simplify). Having the speakers I have I am not interested in exploring subs, but if for any reason I was selecting speakers from scratch I would certainly be want in a listen to some variants like, perhaps, ATC SCM40A with either top end REL subs or Wilson Benesch Infrasonic Generators.
