What is the requirement for a radio stream that requires login to work onn naim radio
I have 2 online radio stations where I pay t to fund the radio. However none of them will work on the new Naim radio.
Folk Alley not so important since the only thing you get is a add free stream, but no extra it seems.
The other station is different. Radio mars from Denmark found at www.radiomars.dk
The main stream is on the naim radio, however access to shows on demand only works either from web after login or using the radio app they use for streaming.
What should they change so that the added station would work with login and showing the on demand streams?
Claus
Can you not use Chromecast or Airplay from the radio app to send streams to the Naim unit? Failing that, Bluetooth.
If you post your request on the official ‘new Naim radio’ thread you will probably get a response from Steve Harris at Naim.
Chromecast only for the live stream that is in the naim radio already. airplay from the app but sometimes their implementation gives up in the middle of a program and then I have to start all over again. On demand in the radio would be a much better ooption if possible. This is a new radio and they are very low onb money, but if the fix is simple I am sure they would make it.
