Apologies if this has already been explained on other threads. I could not find anything.
I’m trying out tidal, I use Roon with Squuezelite (which has identified a number of end points, of which I use a series of Unitiqutes) and with a Sonore Bridge (set up for my NDS).
Tidal, in her wisdom, selects music with MQA embedded, if that’s the word, when I start iRadio. Could someone please explain a few things for me.
Why can I play some MQA through the ‘Qutes and not others?
Of course, the NDS feed behaves normally.
I can’t use multiroom with MQA files.
Is there something I can set up in Roon to improve the MQA experience?
Does bit depth conversions make any difference to MQA playback and SQ?
I suspect David’s explanation is correct, the streamer can’t multiroom hi-res music. It would have saved people a fair amount of head scratching over the years if you got a message on the screen explaining this, rather than just silence!
