I have to partly correct my somehow impulsive dismissal of most Focal speakers - I visited my dealer yesterday and although it was not the right moment to carry the Focal Kanta 3 downstairs to the 252/300 system, I could again have an exhaustive listen at the stand mount Sopra 1 with those electronics.
The room is a circa 25 m2, professionally treated one; Sopra 1s were at least 1 mt., away from all walls and the speaker cables were the there ubiquitous Nordost - I believe those specific ones to have been something costing like a decent pair of speakers. So apply the type of mental tare you think proper.
After so many years, and having trained ears for music it doesn’t take me weeks to understand a piece of gear; I don’t say that the Sopra 1 ‘had me at hello’ but for sure in the end I was totally convinced and delighted with the session. They have a marvellous, smooth, rich, open and detailed upper range which really opens a window on the recording, without harshness and with a confounding clarity of each instrument or voice’s position in the virtual space; bass is still a bit stiff and doesn’t yet go as low as it will in a week or so, but it’s there. 3D imaging may well be an HiFi artefact but that artefact was enormously entertaining…
Their overall balance may be a little tilted upwards but they surely don’t lack body, and the integration between woofer and tweeter seems optimal. That is to say that I have checked Focal’s price list here, and while the Kanta 3 is €10,000 the Sopra 1 is 7,500. I don’t remember how the Kanta 3 sounds, but I would most certainly save 25% and go for the two-way: I can’t see how one could wish for something more and why one should want two or three woofers when one seems able to fill a modern room with ease and authority.
My opinion only, but you mentioned the Kanta 3 to me so these are my impressions.
Best,
m.
P.S. After a long listen with the Naim combo we tried the amp I currently have, a 40 W tube integrated with a price tag almost exactly 1/10 of the 252/SC/300DR. Although less wide, spectacular and assertive than the Naim, the smaller amp was able to make the Sopra 1 retain a beautiful, natural voice, sufficient SPL in the room and most of the qualities of the larger amplification. You don’t really need to spend a fortune to drive those speakers. Please don’t consider this as advertisement or endorsement because I have never loved Focals and mine is a completely unbiased, as well as unexpected, opinion.
m.
Thanks very much, they are certainly worth a listen then. Based on what I read, the Kanta seems to be a bit less bright than the Sopra. The standmount vs floorstander question is, I believe, always about the difference between the 45Hz at -3 dB of the Sopra 1 vs the ~35 of the 3. Whether this is worth it - good question. I’ll put the 1 on my audition list
I guess some could find the Sopra 1s ‘bright’ in some environments; to me they sounded luminous and not fatiguing at all. But then, my ears are not those of a 12 years old… Anyway, yes, I think they are definitely worth a listen.
It will be a question of ears, room, and music. “Too bright” was a common complaint for a long time in the Focal Sopra (and above) & Naim comments, and less so for the Kanta, I believe. Everyone has to listen for themselves - my room most likely favors a voicing that is less on the bright side, but will have to try
I use Active Ovator s800s with my NAIM kit and absolutely love them. I have no intention of changing them ever. Detailed, dynamic, (they can be delicate too) punchy, and fast. You should hear Slipknot at volume - shakes the street.
They actually look pretty good in this picture and in this setting. In real life I find them oppressive-looking, possibly the listening distance makes a difference. I have a 2.6m equilateral triangle and their looks scare me at this distance.
One word of advice is that I was also looking for speakers for a similarly large space. And like you, the listening area was effectively a subset of the room (i.e. speakers not firing across the whole space). In the end you don’t always want the volume levels at one end to have music on the other. So even though my speakers can fill the space we ended up getting a Qb for the other end (kitchen).
Thanks, thankfully not an issue and I can invest the Qb money into the real speakers
It’s like this:
The upper part in the picture is Tai Chi area essentially, i.e., empty apart from book shelves along the walls and a rug on the floor. As you can see, the system (and TV as well) is in the lower half and essentially one room with the kitchen. (The outside walls left and bottom are all large windows, so there’s some improvement potential there)
I forgot, what speakers did you end up with and are you happy?
