What should be in here?
A turntable packing insert is my guess, but for which one?
LP12 by the looks of the LH packaging with the concentric circles. What’s on the back of the RH polystyrene insert?
Are you genuinely flummoxed or just testing our knowledge? The box is underneath!
One says base and the other says top. LP 12 is most likely, bought second hand in a non Linn box but with inserts. Thanks
Left is base for sure. The belt goes in the inner circle and the platter on top in the outer circle. Then the plinth sits on top.
