Hi Mike-B, KJC, Pete_the_painter,…
What’s interesting here are the different interior options.
Here in Sweden it is used very,very little carpeted floors in homes.
We used carpeted floors in the 1970-century, but the last decades there are not many who use it in Sweden.
Hardwood Floors,…and different types of plastic flooring,are the most common in Swedish housing.
But in Music/listening-rooms,…hardwood floors are most common.
This in combination with different materials in the walls (concrete, wood, plaster etc).
You should also consider that Swedish homes are very well insulated,this naturally affects the acoustic conditions of the room for the better.
A carpet mat in a Swedish listening room, makes the room in most cases a bit over subdued.
Therefore,…no one,or very few who use it in Sweden.
So we work with slightly different conditions in different countries,…when we decorate the listening-room for the best soundquality.
But what always applies is that…
Make the loudspeaker decouples from the transmittable vibrations of the room as much as possible.
That’s what I did with my experiment at the end of the 1980-century…
I drilled through the wooden floor,…and screwed powerful bolts directly into the underlying concrete.
On these bolts I placed the speaker stand.
You should do this,…ONLY when you know EXACTLY where your loudspeakers should be placed.
It was an incredible boost in Soundquality with this experiment.
Therefore,…I went ahead and made this polished concrete floor…with a very good musical performance as a result.
As I drove active Isobarik,…they should stand against the back wall.
So,…I just needed to make this polished concrete floor 65 cm out of the wall.
Then there was also plenty of room for my Hifi-rack.
I know this is a little special solution,…
But the musical improvement is exceptionally good.
Many Companies sell solutions (see picture below),which is based on what I have done…to solve the problem and give your speakers better conditions.
However,…I took the step fully and made it 100% at once.
/Peder🙂
