You’ll rarely go wrong if you get things that are the same size. Supernait and CDX2. 5 series player with Nait XS.
You’re being modest lol.
Thantks to all. Very interesting your methodological guidelines.
Choose the loudspeakers first as they will have the most impact on the sound and on the gear you choose to drive them properly. This choice of course also depends on the room you want to place your system in. I would work backwards from that and see what budget you have left for the source and amplification and then make a decision.
If you narrowed the speaker choice down to the 2 models you are mentioning (assuming you like both) i’d probably go with Iota Alpha because they are easier to place in the room and do no require dedicated stands. The P3ESR will probably be more difficult to drive properly and also more difficult to place correctly, depending on what options your room gives you for integrating them. They will probably require more effort to get the most out of them compared to the Iota’s.
According to reviews the P3ESR (non XD) is also quite different than the new XD version (which is also more expensive than the Iota’s) so you might also take that into your consideration.
Let us know which way you went and if you are happy with your choices!
