Hi,
When I try and search for Greatest Hits Radio there are no channels for Scotland. I have been using CFM (SW Scotland & Cumbria) but for some reason today it has disappeared from the list of channels and now I can’t find a local station.
Has anyone got any ideas??
We get an fm signal for GHR round here which may help if you still can’t get it digitally and you have fm tuner! Weak signal but my tuner does a stellar job of boosting it.
Edit. In fact when I look there are still half a dozen Scottish ones.
Do you have a Qb2, or the original. All the Scottish GHRs are there on my Qb2. If it’s a Qb1, then the problem is that the radio supplier vTuner is out of action. Naim will soon be bringing the new iRadio to the Qb and earlier streamers.
