I seem to be in the minority who really enjoys the SN1.
In case itās helpful Iām going to share a bit of my journey with it below and ultimately explain why I passed on a good price for a SN3.
The TLDR would be that if you enjoy it as I do:
- Upgrade your source first!
- Consider a Hi-Cap + Re-Cap of your SN1
I go and hear demos of other gear and come back home satisfied with what I own.
I feel like Iām at an extremely good place from a price/performance/enjoyment perspective.
Often I encounter gear/demos and find that it is ādifferentā not necessarily ābetterā.
If they are ābetterā then I reflect on the $ necessary to make, what so far has always seemed like, an incremental improvement.
I purchased my ex-demo unit in 2011.
My system always puts a smile on my face and pulls me into the music.
I find it to be very engaging and fun for the diverse range of music I listen to; basically everything except punk and country.
A few changes I have made over the years have slightly changed the character of it though.
For lack of better words, Iāve traditionally described my SN1 as āwetā or āmeatyā.
Some may interpret that as loose, but it didnāt really seem that way to me at the time.
It has always been FUN.
Iām not sure if those resonate or make sense, but almost all the changes that Iāve made in my system subsequently have made the presentation might drier, and perhaps tighter sounding over time.
The addition of a Stageline N being powered off of the SN1 made the system less dynamic.
Adding a Hi-Cap 2 addressed this and improved the overall sound.
This was a long time ago, but this is my recollection.
Upgrading my Hi-Cap2 to a Hi-Cap DR changed the tonal character of the presentation slightly.
It definitely became drier and tighter sounding.
Still very enjoyable, and I was quite happy with this for a long time.
I had a home demo of the nDAC years ago and fell in love with it, but I couldnāt make it work financially at the time.
Along the way there have been opportunities to trade in/upgrade to SN2 or SN3, but Iāve been mindful that I have a history of neglecting my sources and resolved to address that first.
Early last year I found a great deal on a local used a nDAC recently and it has been a monumental upgrade in my enjoyment of the system.
The SN1 is absolutely resolving enough to benefit from improvements in someoneās source and my enjoyment is through the roof.
Your BlueSound Node2i is a decent digital transport into a better DAC.
While the SNAITās internal DAC is decent, youāll find it is now easily bettered.
I came across a particularly good deal on a SN3 last year, but ultimately decided to re-cap my SN1.
My SN1 is a 2008 model (I believe?) so it was overdue for a re-cap.
I was skeptical that there would be much of a change, but the price of the service was reasonable and I figured it would help with resale should it come to that in the future.
It has once again tightened up the presentation and bass is more fleshed out and deeper than before as well. My enjoyment has increased again and itās pulling me into the music even more than before.
There definitely was a āsettlingā / āburn in periodā as straight out of the box I was likeā¦ oh no what have I done, but it has continued to improve.
I personally wonāt consider something until it is a meaningful improvement in enjoyment over the SN3. It is likely that I would need to go separates, which will be tens of thousands in outlay. That simply isnāt in my near future.
So I guess in conclusion I would say, if you like how the SN1 sounds the re-cap and used Hi-Cap are quite cost effective.
However, as a long term user of the SN1ās internal DAC, I would suggest your next upgrade should be a better DAC. Lots of good options out there, go have a listen
Nathan
