What's Playing On RP?
What’s playing through my ND5XS2 and showing on the Naim app bears no relation to what shows as playing on the RP website at See what's playing on Radio Paradise
This is the FLAC stream of the Main Mix. I don’t use the facility to skip tracks - I just start and stop the stream when necessary.
It’s just finished Lullaby by The Cure and has started on Altin Gun. Neither mentioned on the what’s playing list.
Anyone know what’s going on?
I think this is due to the way that RP ‘broadcasts’. They seem to have timed blocks of some sort. I have no Naim streamer but my various other streamers can be out of synch by a considerable number of songs if I have started listening on one and then stopped play, and then restarted again. I am sure someone on here will have the technical explanation.
Same experience listening to RP via Sonos
Yes - I have this sometimes too. Not consistent though. Occasionally off by miles, but mostly near enough to correct. Listening via Roon in my case.
