Greetings from Mechanicsburg, Pennsylvania.
So far, I’m loving the sound of my recently acquired XS-2 (60wpc version) and CD5x. The CD5x has been powered ON since Feb 17, 2019 and the XS-2 since Feb 20, 2019. By the way, I’ve heard it can take weeks for Naim components to fully warm-up and sound their best? Is this true?
This post is regarding cabling. I’m curious as to what the consensus is among Naim owners regarding cabling? And, how did you arrive at what you’re using? Did you do a lot of comparing beforehand?
I’m currently using Mogami W3082 speaker cable and Mogami W2549 RCA interconnects. Speakers are Vandersteen 2C’s. I know Vandersteen may seem odd, but this combo (to my ears) actually sounds really good together. Of all the gear I have owned over the year, the Vandersteen 2C’s and the Mogami cabling have remained.
Interconnects:
I’ve been reading and getting feedback that DIN is the best connection method for Naim gear. I did pick up a used original Naim 5-pin DIN to DIN interconnect (grey color) to start my own comparisons. I should have the cable by week’s end. Of course, after I bought this cable, someone mentioned the Lavender version is the better sounding of the two?
Speaker Cable:
As for the NACA5 speaker cable, it seems folks either love or hate it. There is a company called Witch Hat Audio that makes naim-specified cables and interconnects and is reportedly very good? In fact, this company is owned/ran by ex-Naim engineers. Anyone have any experience with their cables?
Even looking at the technical specs of the NACA5, the Mogami W3082 I’m using is much higher in capacitance (253pF/m) vs. NACA5 at 16.5pF/m. It seems though the speaker cable requirement isn’t an issue with the newer Naim components, but I was curious to see if there is a Mogami cable with closer figures. W3103 for example, has a much lower capacitance of 93pF/m at 1kHz, and 83pF/m at 10kHz, vs. the W3082. However, it’s still higher than NACA5.
I have some Audioquest CV-4 I tried on the XS, but it added too much artificial bass. It sounded like someone turned up the bass knob. When I went back to the W3082, it balanced everything nicely. Mogami is a very neutral cable in my opinion.
