and this is the back
Did you connect a Snaic 5 to the end socket on the 32, the one with the little round cover? Thatâs where it should go.
This is the unofficial snaic 5 from flashback, isnât it? Maybe itâs not wired properly. You could take it apart and have a look.
The bottom picture explains it to you - socket 3 to pre-amp (single rail supply - see the +ve). Socket 4 is for pre-amps that can take a Hicap (dual rail supply - see 2 x +ve).
So why socket 2 should be successfully powering your preamp with the SNAIC4, I just do not know! Are you sure you donât mean youâre powering via socket 3?
I have made other attempts but the only way to work is with the snaic4 cable.
I think I will run the service soon.
SNAIC4 via socket 2 or socket 3??
