Trying to connect my nac-n-272 to a new nap250 dr unsure which cables I need thanks for any help regards T
The DIN4 to XLR cable that came with the 250DR is what you need
As James says….the cable should be in the box with the 250.
I bought it on the bay power cable was the only one will give the seller a email thanks
