Evening
Just rigging my Nac 72 up to a new/old Prefix phono stage from its dedicated Hicap.
Which input on the 72 is regarded as the best?..CD, TUNER, TAPE 1 or TAPE 2?
I’ve re-soldered the link wires back into the 72 and removed the phono boards.
Many thanks
Clive
I’d go in via the Tuner input. Hopefully you have the required 4-5 interconnect.
Hi Richard. Many thanks for you quick response.
Yes I have the 4-5 pin Naim interconnect.
Do the tuner input slots need to be empty?..
Clive
The tuber input is direct on the PCB so no cards. Obviously no good if you have a tuner already using that input…
Come to think of it…which socket in the Hicap do I use? they’re all 4 pin!
…tried looking in the manual but no mention of the Prefix?
james_n
8
Your Prefix should be connected to socket 4 on the Hicap so connect the DIN4-5 interconnect to socket 3 as it’s the closest to socket 4.
Many thanks…I’ll try that.
system
Closed
10
