OK, this has come up lots of times with view both sides, and never a consensus (as if we ever do ) so thought a quick show of hands may conclude where the support is - Thank You!
Update - this would be for an NAC82 or NAC282 - I would imagine the answers would be the same
2 HiCap DRās
1 Supercap DR
0voters
Iām just thinking about box reduction more than anything from my 2 HiCaps, but want to judge if this might be a bad move as of course there is no demoing these now
With either a nac252, superline or even possibly a snaxo (unless using lesser NAPs), only a supercap will do?
The question is imho biased, without a system config.
edit: iirc the supercap isnāt fully utilised by a NAC82 and hi-caps x 2 is the same shelf space as a s-cap, so interested to know how this amounts to box count drop, if measured by shelf space?
Box count, not space.
Advantage of a SC for me would be a spare powerline to sell, and overall service cost would be less, and possible SQ improvement. It would allow a 52 in the future, although thatās probably not happening.
Appreciate the logic, fair if I donāt vote, I went from one h-cap to a supercap, interestingly on NAC82.
From there when dealer offered ex-dem (or maybe a trade in) 252, I was set, I thought.
The 252 wasnāt for everyone, but I enjoyed it, until an exdem 552 fell into my orbit, in a deal that was a no brainer.
Just a thought, did the 52 have its own ps for a time (initially) or could it always be powered by a supercap?
I guess it has been mentioned occasionally on the forum, hence my observation.
Iāve never been frustrated by upgraditis, as it seems to be called. I settle and then enjoy for a long period, perhaps until a service presents an opportunity. At some stage downsizing et al will have to be faced, but Iām holding out.
I was though enthusiast for a NSC222 in the kitchen diner, tricky room acoustically, a Nova + S400s were lost; NC kit just sorted it all (bought unheard but I didnāt say that!)
AI has the answer to everything- data in China but Iāve taken one for the teamā¦
When comparing two Naim HiCap DRs to one Naim SuperCap in terms of sound quality, the choice depends on your system setup, preferences, and the specific components youāre powering. Hereās a breakdown to help you decide:
Two Naim HiCap DRs
Advantages:
Dual-Mono Configuration: If youāre using two HiCap DRs to power separate channels (e.g., one for the left channel and one for the right), this can provide better channel separation and a wider, more detailed soundstage.
Flexibility: You can allocate one HiCap DR to power the preamp section and the other to power a critical part of the system, which can improve overall performance.
Cost-Effective Upgrade: If you already own one HiCap DR, adding a second can be a more affordable upgrade path compared to jumping to a SuperCap.
Disadvantages:
Complexity: Managing two power supplies can be more cumbersome, and youāll need the appropriate cabling and setup.
Space: Two units take up more space than a single SuperCap.
One Naim SuperCap
Advantages:
Higher Power Reserve: The SuperCap has a larger power supply capacity, which can deliver more current and stability, especially in demanding systems.
Simpler Setup: A single unit is easier to manage and requires less cabling.
Refinement: The SuperCap is designed as a higher-tier product, often offering a more refined and controlled sound with better dynamics and lower noise.
Disadvantages:
Cost: A SuperCap is significantly more expensive than a single HiCap DR, and even more so compared to two HiCap DRs.
Less Flexibility: While itās a more powerful unit, it doesnāt offer the same dual-mono flexibility as two HiCap DRs.
Sound Quality Comparison
Two HiCap DRs: If configured correctly (e.g., dual-mono), this setup can offer exceptional channel separation, detail, and soundstage width. Itās particularly effective in systems where powering different components separately can yield noticeable improvements.
One SuperCap: Generally, the SuperCap provides a more refined and authoritative sound, with better dynamics and a quieter background. Itās often preferred for its simplicity and overall performance.
Which is Preferred?
If you value dual-mono operation and want to maximize channel separation and detail, two HiCap DRs might be the better choice.
If you prefer a simpler setup with higher power reserves and a more refined sound, one SuperCap is likely the better option.
Ultimately, the best choice depends on your system, listening preferences, and budget. If possible, audition both setups in your system to see which one aligns better with your expectations.
@Straydog1
Being a bit provocative to be honest, we just love our 82 non DR SC, it rocks like wow, but I have seen comments in the past mentioning they prefer non DR, wonder if JV was involved in DR? Interesting
Martin
Both have the same transformer and capacitors, main difference is SC feeds seven regulators, while HC feeds just one. With the HC you get a dedicated transformer and pair of capacitors per channel, I donāt see how the SC can be better suited.
You neglected to mention, a SC provides a single path to earth, whereas two HiCaps will unfortunately provide two paths to earth for the same preamp. Thatās not ideal.
Also I donāt think power reserve comes into this at all. The output is non variable DC and. The current output on both is only suitable for 0.3A. The over specced transformers certainly deliver stable current well isolated from mains but these are not power amps so āpower reservesā wonāt be an issue. Both HiCaps and SuperCaps have sufficient large capacitors after rectification if that is what you are referring to. But that primarily plays a role in smoothing as there are no appreciable transient draws in their use case.
Thatās not quite true. Because the SC has one earth. Itās not different from the multiple grounds in any product that meet in the same place. There is ultimately a single path to earth for the product. When using two HiCaps there is one earth per HC. One HiCap carries signal ground to earth plus the standard reference and itās own safety ground, the other carries only reference and safety ground. With a Supercap, they all meet in the same place - itās a single path to earth. .
But the 282 has two. The minute differences in cable length, resistance and connection efficiency will inevitably cause a ground differential. The SC may have have one reference to earth, but the 282 has two, whether connected to two HCs or to a SC. Two cables carrying ground, two references to ground. Itās unavoidable.
