Simple question (I hope): Will the NARCOM 5 remote control work with old Olive gear (52/52PS and CDX) and, if so, will it work simultaneously with both the 52 and CDX?
All the Narcoms are RC5 so should work fine on old and new kit. Only the very first NAC52s used a different proprietary remote code set and Narcoms won’t work with this one unless it’s had a display board update.
