How do I find which tablets will support the Uniti Atom app
Any fairly recent Android or Apple tablet will work. I use a Samsung and it is perfect.
Any device that runs iOS or Android will work. If they are old you would need to check that they are running OS13 or later. Not sure what the Android equivalent would be.
I use both my iPad (5th Generation) and iPhone (8 Plus) with the Naim App.
I use an iPad - so I can have a bigger font and icons!
