Who do I tell?
One of the listed radio streams in New Zealand BrianFM have updated to a new source and upgraded but rate to 128k and significantly improved dynamic range.
Who do I inform in order to have the source added?
Assuming you have a Naim streamer, if you’re sure the station isn’t hidden away in the iRadio menu, you can add it manually at naim.vtuner.com.
Alternatively, @Stevesky may be able to add it to the iRadio directory.
Thanks Chris, I’ve previously added it to my added stations, so I’m essentially trying to get the naim listed iRadio entry updated to the new source. I’ll try @stevesky.
Azher
