When I select Classic FM via my NAC-N 272 streamer’s iRadio facility I am told what music is currently being played, but no such information is provided for BBC Radio 3 (or Radio 2). In contrast, the DAB radio on my wife’s 2017 VW Golf shows the current track for Radio 3.
Has the BBC made a deliberate decision to exclude such information from their Internet streams?
It’s probably because they distribute everything as one type of high res stream and then transcode it wherever and whenever a different (ie lower res) stream is needed. But adding in the metadata to every instance of transcoded data wherever that takes place is going to be tricky. In other words it’s not about cost, but technical complexity.
This is likely due to having been starved of cash for over a decade much like another British institution. Despite this, they do well as far as I am concerned even if I don’t like some of the recent changes made to R6.
We’re in danger of going down a different rabbit hole here As I’m sure you know, I was simply picking up on your suggestion that the BBC couldn’t cope with providing metadata on its Internet radio streams due to technical complexity. It can’t be that complex if Classic FM can do it.
Hmm. In addition to my NAC-C 272, I also have a Muso 2 and a Muso QB 2, which I have always thought were Naim’s “smart speakers”. I wonder how Sonos can display the metadata when none of my Naim kit can do this.
You prompted me to search this forum to find out if Naim supports the BBC Sounds app and this took me to another thread that told me “You can use AirPlay or Chromecast to stream from the Sounds app. The BBC channels are all available on the Naim app iRadio input, along with some on demand and podcast material, but the Sounds app is a better interface”.
I’ve now installed BBC Sounds on my phone and have successfully Chromecast Radio 3 to my Musos. It looks like I will now stop using Naim’s iRadio.
Many thanks for pointing me in the right direction
Yes, on the BBC Sounds app you can clearly see the cast icon. The good thing about casting a radio stream as opposed to local files is that Chromecast’s lack of gaplsss playback isn’t a worry.
I’ve now installed BBC Sounds on my iPad and am simultaneously playing this via Airplay 2 on all my Naim devices. That’s better for me than Chromecast.
Not quite David. I watch a lot of tv legally without a license.
Only programs that are viewed whilst they are currently being broadcast and I player need a license.
Any catch up service,Netflix, et all do not require the purchase of a license.
You must be covered by a TV Licence to download or watch on BBC iPlayer – live, catch up or on demand. This applies to any device and provider you use.
