Other than a different field strength pattern, no.
I high efficiency Toroidal transformer can more easily saturate and can actually create more EM pollution than a low efficiency transformer when saturating.
The main advantage of the larger Toroidal transformer is its lower source impedance, hence load regulation,
You´re looking at AC mostly but you are right with what you said about transformers.
But effects that can easily be heard are more likely related to the DC section of an amplification stage. Separating DC for any stage better isolation of the stage and higher resolution capabilities of the so operated amplification stage. Same with reducing ripple in DC.
Reminds me of the construction of the Statement as shown in the Hi-Fi News picture as part of their review. There is a very earnest looking middle aged man in a white coat using a block and tackle. Similar to the removal of an engine from a car.
Itâs a design choice like any other. Both have strengths and weaknesses. Donât beleive anyone whoâs convinced in the absolute superiority of one over the other.
I agree with you on this point, but I would assume that Naim uses remote sensing to minimize the source impedance of the active wires. Afterall, with all those lines in a Burndy, they have space for it.
If they do I have never heard them mentioning this⌠other than local regulators are used on many of their source devices.
But they do have power burndy management⌠so if the valid power combinations are not provided the device will flag an error and not enable to prevent damage. (Flashing LEDs etc)
