Hi there mm would second the vote for a netgear orbi- wonderfully simple system that worked well for me for years and better than the alien like night hawk.
However if you want something truly Naim like in its flexibility, ability to be tuned to your house and want to build a wifi system, etc check out the ubiqui UniFi range. I think they also have a consumer grade range too.
In the UK some of the best consumer access points are the BT wifi discs (Whole Home Wifi 6) … plug and play, and hugely popular… especially for home and small office… the only downside I don’t believe the access points PoE. If you want PoE then the Ubiquiti Unifi ‘prosumer’ devices are excellent, but not so plug and play, they require some basic configuration.
