I’m currently using an Ethernet cable from my mesh box direct into my Naim ND5 XS2. I was using the Wi-fi antenna but have have now hard wired it. Is it ok just to leave the antenna screwed into the back of the streamer or should I disconnect them? By using an Ethernet cable am I by default bypassing the antenna?
Either leave it there or keep it in the box, doesn’t matter.
Stick them back in the original box. If you are hard wired they will do nothing now. Saying that, I’ve never taken my out the plastic bag. Hard wired from day one.
Great. Thanks
