Wanted to add to this thread to share what happened with my Uniti Star’s network configuration when updating to a new Sky router yesterday. This required a change to the WiFi SSID and password. There is a new and unexpected (for me) behaviour in the Star’s network configuration process, certainly since the last update to Uniti system firmware version 3.10.0 (5998
I’ve had my Star for nearly 10 years now, going through many firmware versions. I have also changed WiFi routers, SSIDs and passwords numerous times in that period, and always did this using the Uniti remote control selecting either
Home > Settings > Network settings > Network Setup
or
Home > Settings > Network settings > Wireless Setup
In the latest case yesterday the Star surprisingly and consistently failed to authenticate with the new Sky router despite the new router’s SSID being detected in the Star’s network settings scan, and me supplying the correct password through the Uniti remote control. I tried power cycling the Star and the new Sky router, used factory resets, etc, but the Star would not authenticate with the new router. Also tried avoiding the password step by using the WPS button on the Sky router. I even hardwired the Star to the new router and that worked fine. But ethernet cabling the Star to the router is unacceptable for me. Has to be WiFi in my case.
The failure occurred after entering the network’s new password. You get the message Failed to join network
on the Star’s display.
All other devices in my house connected to the new Sky router with no problem, either by manually supplying the network password, or by using the WPS button on the new router. I even tried going back to the original Sky router in case the new router’s security was hitting an incompatibility with the Star. This step also failed.
Following JonathanH’s suggestion I then used the Naim app on my Apple tablet to connect to the Star. Note, the Apple tablet had successfully joined the new network. Connecting to the Star from the Naim app then failed because, of course, the Star was not on the new network. However, I then used the Naim app’s Add New Device
function and selected Uniti Star. This detected my Star and prompted for the network password from within the Naim app’s user interface. Supplying the new password through the Naim app was successful and allowed the Star to join the new network. Thank you JonathanH!
In conclusion, if you have to update or change your Wifi router, you will probably have to change the SSID and new password on your Uniti system. If you do this through the Uniti remote control and your Uniti fails to join the new network, then use the Naim App to enter the new Wifi password.
