when I select a song from Tidal it says it can’t connect. Unless I’m missing something I must be connecting when I play my playlist.
Have restarted the router and modem and SuperUniti says it’s on my home network.
SuperUniti 4.4 iPad Naim app.
Hi, if it’s a problem connecting to the Tidal server, sometimes it helps if you sign out of Tidal in the Naim app, then sign back in.
Also, updating to the latest firmware (4.7) would be worth doing.
Thanks ChrisSU. It seems to have resolved itself. Appreciate your help.
