Will podcasts ever get added to Naim radio?
Now that iRadio has moved in-house and stabilised, was wondering if anyone knows about further development to include podcasts? Most are free to carry, so it’s probably a technical issue more than anything to develop, test, and roll out.
I can see where most wouldn’t be clamouring for this as they’re available via Apple Music, Spotify, etc. but would be really nice to control everything from the Naim app for those on 1st gen streamers. I was just trying to stream a podcast from Spotify and oddly it will stream to my 172 but not my UQ2. And they both have the same firmware, streaming board.
Just curious. Possibly a question for @Stevesky :thinking:
There are lots of podcasts already available within the Naim app iRadio section. Whether this will ever match the selection available elsewhere in podcast apps, BBC sounds etc. is another matter.
I’m struggling to find any of them. Where would they be?
Hi @Maury_Finkle
Currently we only do Podcasts created by radio stations, rather than the full spectrum from the various companies focused on only creating podcast content.
Example:
In Uk go to Brands → Times Radio
Select Podcasts:
The podcasts for that station shows:
We decided not to create a full blown podcast solution as:
  • A lot of the more popular stuff have exclussive deals with Apple and Spotify, and various requires subscription.
  • We’re recreating something that others have done already and we can’t add any value to it.
We implemented radio only ones so customers didn’t loose functionality as we switched away from VTuner. I’m sure there are some exceptions here, but we’ve covered most stations,
Best
Steve
Thanks @Stevesky ! That all makes sense. I had no idea those were embedded in there. You do need to know what you’re looking for then.
For the rest, I suppose that’s what AirPlay is for :grinning_face: I’ll continue to listen via bluetooth from my phone when the mood strikes.
Hi @Maury_Finkle
On Podcasts app it comes down to:
Spotify → Spotify Connect
Apple Podcasts → Airplay2
Other apps → Googlecast or Airplay2
Bluetooth as you mention can also be used with usual disclaimers of keeping phone in range etc.
Best
Steve
