Presently I use the above combo in my office/studio. The PC keeps disconnecting from the DAC quite frequently. I have tried altering a couple of Widows settings, to no avail. I did not have this problem with Windows 7. Does anyone have any idea how to fix this please?
Do you have the latest firmware on the DAC …does WIN10 need the driver?
Sorry if obvious.
Hi Klyde,
I think this is to do with USB power management on some chipsets. Disable it and hopefully all should then be good.
Screenshot attached of area in Windows to adjust:
Best
Steve
Thanks very much Steve. I’ve disabled the USB power suspend setting and will see how it goes.
Best Regards
Phil
