My son is home and playing music from his Spotify through my ND555 from his iPhone. All my Bluetooth, Airplay and Chromecast inputs are disabled.
How is the connection being made?
Spotify Connect still enabled?
It’s possible to use Spotify via AirPlay but Spotify Connect is their proprietary method and is integrated into the Spotify app, so that’s what you would enable/disable.
Spotify and airplay are not enabled. Hmmm
Once a Spotify user has connected to a streamer, disabling the input will not prevent them from connecting to it again. Spotify Connect is kind of pushy, to the annoyance of some when previous users have given them a shock by accidentally connecting in the middle of the night.
That explains it. Thanks.
