As HH said in his reply, this should not be the case. As ChrisSU said in the other reply, it can happen if the router is really shitty or someone misconfigured it on purpose (or in hybris). But I have never seen anything like this in 30 years of computing. It’s as wrong as your car not starting because you didn’t wash it
Is running an ethernet cable across the floor from a Mac (so that I can still reach the app) really better and easier and more robust than just buying (say) a Marantz SA-10?
To each their own, of course. My wifi has not been down (other than a very rare need to reboot the router) since I had wifi, which is about 20 years. And I never did anything special either, and always lived in apartments in densely populated areas. Reliable wifi was, though, indeed for a long time a problem in large spaces and buildings of certain construction. Gladly, mesh wifi has fixed this more or less. (Though if one can’t install it on their own, I guess it can be not that easy to find a good service provider who can)
In any case, to me the answer is yes even if I had to run a length of ethernet cable occasionally (which just doesn’t happen). CD players with all their high-precision moving parts that are prone to failure, and their scratch-sensitive discs, are IMHO a crazy (impressive but crazy) contraption that would never have seen the light of day if another way of storing and delivering music digitally had been possible in the 1980s.
And they don’t even have any metadata. People complain if the metadata on downloaded files and rips is not perfect, but CDs have none and this seems fine. The booklet of course, if any, but this does not disappear just because the CD gets ripped.
I am aware that my Mac has lots of USB-C ports, but no others.
USB-C-to-Ethernet adapters are available and cost about 10 euros. (Maybe 50 for the same if buying from Apple).
Also, this may work for me and others who rip now, but for a lot of the non-ripping over-65s the above will be as comprehensible as Sanskrit.
True. But nearly anyone can stick a CD into a Naim Core or into a Roon Nucleus with an attached CD drive. Although I appreciate that issues can occur that seem simple (if annoying) to some, but may be a major problem for others, which is not necessarily their fault. On the other hand, CD players can also develop issues that normal people can’t solve.
The problem is, simply, whether the remaining people who can’t/won’t do that provide enough of a market to make a sustainable business case for developing top-of-the line CD players. Maybe they do, and more power to them and the businesses catering to them. But it will have a limited life time.
Having said all that, I didn’t know that plugging in a cable to a Mac would definitely work and (for example) that the app won’t be fixated on not finding a ‘room’ by wi-fi), so I am grateful for the comment.
I would recommend trying this in a calm minute when everything works, instead of when it has failed. Stress and unknown failure modes make it harder
